12-26-2016, 10:04 AM   #1
cooltouch's Avatar
MX Mirror Stuck
I bought this very clean looking MX earlier this year. Halfway through the second roll of film I've put through it, I noticed a problem with the mirror. At first, it wouldn't return after I tripped the shutter, but I was able to wind the film on. And then if I tripped the shutter again, the mirror would return. This condition persisted for about three of these double actuations, and then it stopped altogether. Now, the mirror is stuck in the up position and I can't wind the film on or trip the shutter.
I'm gonna remove the bottom plate and poke around in there some, see what I can find if anything. I can remove the top cover too, if that will do any good. And if I have to, I can remove the mirror box, but I don't really want to have to dig into it that far.
So, any obvious places I should look that you might know of?
I think I'll go visit YouTube, see if anybody's posted some MX repair videos.
12-26-2016, 10:26 AM   #2
gofour3's Avatar
QuoteOriginally posted by cooltouch Quote
It could be the mirror foam gone bad and it's now sticky, so this will continue to happen with your MX until the foam is replaced.
I'd send it to Eric for a CLA.
Phil.
12-26-2016, 01:21 PM   #3
cooltouch's Avatar
Thanks for your prompt reply. For now, I will avail myself of an excellent local repair source: Professional Camera Repair of Houston. They're much cheaper than Eric and they have fast turn-around times. I had various issues wrong with my LX and had them do a repair and CLA. Cost me $80.
I'm rather embarrassed to report that the reason why I coudn't advance the film in this MX is because I was at the end of the roll. I had a roll of 24 loaded and I thought it was 36. Oops.
So once I got the roll out, I was able to advance the shutter again, and I was better able to define the problem. I removed the bottom cover so I could have a look at what was going on down there. Often -- not every time, but most of the time, when the camera is set to one of the slow speeds and when I trip the shutter, the shutter fires but the mirror stays up. Often -- not every time -- when I fire the shutter again, the mirror will not fall. I may have to trip the shutter half a dozen times or more before it falls. Or -- I can set the dial to 1/30 or faster and the mirror falls every time.
I found where the fault lies -- I think. When poking around in the bottom area of the camera, I found a spot where, if I press on it with my tweezers, it trips a spring loaded mechanism and the mirror falls. I can't tell where this spot leads, but it seems pretty clear that I'll have to pull the mirror box to take a look at the way it's operating and find what I need to do to fix it. So that's where things stand, sorta. The camera is perfectly usable at speeds of 1/30 and higher.
When I was poking around down in the camera's interior with a set of tweezers, I inadvertently disconnected a small spring from the slow speed escapement and when I was trying to reconnect it, it fell off its other attachment point down into the bowels of the camera. I've thumped it and whacked it with my hands, trying to get the spring to come back out, but to no avail. I'll probably have to pull the mirror box to retrieve the spring. Fortunately, wherever it fell to, it isn't interfering with the operation of the camera. But now that it's missing from the slow-speed escapement, the shutter no longer times out at the slow speeds. The shutter just fires at a set speed -- probably X or 1/60 -- whether it's set to 1/15 or 1 second.
So, I'm in need of a small spring. Anybody got a parts MX they'd want to sell me a spring from? Here's where it went (the red arrow shows where):
NEX-7  Photo
12-26-2016, 02:17 PM   #4
tvdtvdtvd's Avatar
Hi Michael,
I do have a beat-up, parts MX that I'd be willing to sell. Just took off the bottom plate to verify the spring is indeed there. PM if you're interested
and we can hammer out an arrangement.
However, it's just a simple tension spring and you might be able to find a local replacement for a couple dollars. I was going to suggest
Graingers, but a quick search doesn't show anything smaller than 1/2". The actual spring in the MX looks like it has an outside diameter
of ~1/8" and a coil length of ~3/16". That's just an eyeball guess without actually removing and measuring the spring. You might try a local
watch repair or even the above mentioned camera shop to see if they'll sell you the spring.
However, if you're really hankering for a parts body, send me a PM. (edit: forgot to mention I'm in Austin, so shipping would be
fast and relatively affordable).
PENTAX K-3  Photo
09-13-2022, 05:44 PM   #5
It's a bit of an older thread, but did you get to the bottom of the stuck mirror in the end, OP?
In a similar boat over here!
film, mirror, mx, mx mirror, pentax service, repair, return, service, shutter, warranty, wind
6x7 mirror stuck IgorZ Pentax Medium Format 11 02-02-2017 11:51 PM
Pentax 67 MLO mirror stuck denisbalibouse Pentax Medium Format 3 02-06-2015 02:28 PM
Pentax MX mirror stuck up striker_ Film SLRs and Compact Film Cameras 4 05-07-2014 04:42 PM
MX mirror stuck up - is one of you knowing the remedy? Rense Film SLRs and Compact Film Cameras 8 11-12-2010 04:37 AM
MX Problem - Mirror Stuck Leslie P Film SLRs and Compact Film Cameras 3 11-04-2007 02:28 PM
All times are GMT -7. The time now is 05:28 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
