I have a K1000 that works fine, except the Film Advance Lever is no longer in working order. The gear that meshes with the lever has stripped a few teeth and they appear flat. By moving the lever I can advance the film almost all the way, but it starts skipping and clicking and I have to help it the rest of the way.
There are photos attached below, of the gear that is stripped. Is there any way of repairing the teeth on it without removing it? It's under the ASA/ISO dial and It seems very complicated to remove that portion of the camera, so I would rather not do that. If I can't do this, I will most likely be sending the camera to Eric.
Thanks so much,
oceanbass
