Originally posted by Nass I wonder what exactly an infra red flash emits
The IR flash probably has a peak emission of 900~2000nm where people won't be able to visually detect glow. Basically this is a NIR camera [near Infrared] . Also bear in mind photographic optics are very poor long wave IR transmitters *and films, even the ones mentioned in the brochure aren't sensitive at all to long wave IR. I recall the gasses used in IR flash tubes tend to be rather exotic and thus: expensive.
Originally posted by pathdoc Heat, basically.
This is a bit of an over simplification, long wave IR is harder to detect than NIR** - none of the films mentioned in that brochure are sensitive to long wave IR. Kodak HIE ( which is a pain to handle, and has no halation backing, so say goodbye to micro-contrast) I recall is only IR sensitive as far as 1000nm after that sensitivity drops markedly. Unless you
hyper the film which can enhance its sensitivity - but that is a really esoteric practice.
* Lenses with high amounts of Lanthanum are particularly good for IR photography. Lanthanum added to borosilicate glass can produce a product with a near perfect 98% transmission precisely at 1000nm, combined with gallium the bandpass for IR can be extended further.
** making a digital sensor sensitive to long wave IR invariably involves the detector being actively cooled, sometimes to cryogenic temperatures to eliminate thermal noise from the sensor and surrounding electronics. The degree of cooling required depends upon the spectra you wish to observe.
