Originally posted by pathdoc I quite often stop at #35 deliberately - among other things, the negative sleeves I bought to store my home-cooked B&W negs in are designed to take seven strips of five (though in fairness, 6x6 would be awkward for most folders). Thirty-six shots (or the rare film that I manage to milk 37 out of) can actually be a pain in the neck!!
Yea I've actually thought about that too, cuz while the sleeves we have available to us on campus are good for 6 frame widths, I've had some in the past that only took 4 or 5 (the foldable kinds you might pick up from print labs in the past). Plus doing 5 across would fit easier inside of an 8x10 contact sheet (though might extend more the height, but you could at least get every frame on the sheet even if the edges of the outermost frames get cut off).
The way the MX's takeup spool works, seems like I could easily start earlier and ensure I get at least 35~36, whereas some of my other cameras, usually a single slit take up spool, and not as taut as the MX I tend to go that one extra wind just to make sure it has it caught.
I noticed when I hit frame 36, the little box next to the shutter button shows red, I hadn't noticed that before, kind of a cool visual aid to say "Hey! last frame".
