I recently received this little fix up kit for Pentax MX, ME Super and MV, primarily cuz I thought having an eye cup would be nice, and can't hurt having some of the little sync covers and body cap.
Pentax Fix Up Kit Body Cap Eye Cup for MX ME Super MV | eBay
The problems with said eye cup (which has it's own glass optics, which is convex on one side and flat on the other) that is is :
- you can't load/unload film with the eye cup attached. I'm not talking about just the rubber part being in the way if that was the case I would just bend it up to open/close the door like I have with similar cameras. But the bottom of the framing of the eye cup literally blocks the film door, so you have to either remove or push up the eye cup a bit past the 'locking' snap to do so.
- you can't see the meter reading/shutter on the right or aperture window up top without framing to the extreme opposite edge of the eye cup to see them.
So I'm curious what the original eyecup was like.
