WD-40 can be miraculous when freeing up jammed stuff.
Trouble is, for cameras it should be cleaned all away, and proper oil substituted before putting the covers back on.
WD-40 isn't really an oil. The WD stands for "water displacement", and was intended to get moisture away from where it wasn't wanted. It used to work great on cold damp mornings sprayed on distributor wires.
Anyway, when the lighter solvents dry off, WD-40 leaves a gummy residue. Not a problem for things that are cleaned regularly, like firearms. But a disaster for cameras left sitting on a shelf.
In my experience, while camera manufacturers had lists of specific lubricants for specific mechanisms, a good quality clear "hobby" oil works well for drivetrains and shutter bushings, etc. Lighter grade "watch" oils are better left for shutter escapements.
