Originally posted by pathdoc Sounds like you need an S1a or Sv!
I guess an slr built without a light meter circuit in it might be lighter weight. I have a meterless Zenit, maybe I should weigh it?
The ESII works perfectly in every other respect, unlike my two other m42 bodies, one of which has a working light meter but has developed a shutter problem. The ESII is beautiful, and was found in a bin of five-dollar "Broken" cameras, so it was also a wonder bargain. It also loves my non-SMC Super-Takumar f/1.8 55mm, which it would have problems with if it had a working internal light meter.
It used to be possible to get those meters repaired, but one of the people best known for doing it, stopped when the supply of replacement circuit boards dried up. Of course, it might not be the board; a simple shorted or broken connection elsewhere in the circuit or bad ground could be at fault. But I really wouldn't think of messing with it unless something else stopped working right. And if I don't need the slightly later lenses, there are more of them available for the original poster!
