Originally posted by Ontarian50 Another method that works well requires two things: 1. a lens that focuses exactly at infinity (50mm's are usually calibrated perfectly, test them on another body). 2. a view of a distant object (I use a church steeple a few blocks away).
With the lens and camera aimed at the distant object, your split image on the LX should show you how much adjustment you need to get the mirror perfectly aligned, either through bumper thickness, or adjustment.
If your lens is focused at infinity and your split image agrees, then you're done!
Speaking of, you can bypass the physically clear distant object with this method:
Camera repair pages
