Originally posted by timw4mail Isn't it basically the M42 equivalent of the K1000? I thought those were actually pretty popular.
It is a Spotmatic, though without a self-timer. It differs from the K1000 in that metering is still stop-down and it lacks a hot shoe. The Spotmatic II is actually quite a bit more common and was not that much more expensive new.
To the OP, if you are interested in the classic M42 experience and the body is in generally very good to excellent condition, the price of the CLA by Eric is less than what you would pay for a CLA'ed copy in a shop and about the same as what one in excellent working condition with good seals would cost otherwise. (Even the cleanest bodies on Craigslist or eBay generally required new light seals and mirror bumper, part of a CLA.) Yes, other more desirable bodies may be had for about the same money, but this one you already have.
P.S. BTW, be careful with your S-M-C Takumar and the A/M switch. The switch should only be used if the lens is mounted to the body, has a rear cap on, or is attached to an M42 adapter. There is a tiny pin on the mount face that is part of the interlock for open-aperture metering. That pin must be depressed before using the A/M switch. Note too that some M42 bodies and accessories have screw holes on the mount face that might foul the pin...not good.*
P.P.S. Batteries are not a huge issue. The Renata S387 (or equivalent) silver cell is readily available and works well with the Spotmatic meter in all but the lowest light levels. If desired, adjusting the meter for the silver cell's 1.5V may be done as part of a CLA by most competent techs.
* My Mamiya 1000 DTL will foul the pin on my S-M-C 28/3.5 if extended. Rather than try and remember to always have the switch in the "man" position when mounting/removing the lens, I simply don't use the lens with that camera. I have other 28's
