08-22-2017, 06:17 PM   #1
Spodeworld's Avatar
Super Takumars on Spotmatic F
I'm trying to get an understanding of the differences of the various spotmatics but it is confusing. I understand the the Fs allow for open aperture metering as long as you use a Super Multicoated Takumar. What happens/how do you use it if you put a Super Tak on the F?
Thanks
08-22-2017, 06:45 PM   #2
timw4mail's Avatar
QuoteOriginally posted by Spodeworld Quote
Thanks
I would assume you have to use stop-down metering, like adapting it to the K-mount.
08-22-2017, 07:02 PM   #3
boriscleto's Avatar
QuoteOriginally posted by timw4mail Quote
This ^. It works like a Super Takumar on a Spotmatic.
08-23-2017, 05:04 AM   #4
Spodeworld's Avatar
So, you have to flip the A/M switch on the lens then to meter?
08-23-2017, 06:02 AM   #5
timw4mail's Avatar
Or just leave it in manual if the light permits.
08-23-2017, 10:58 AM - 1 Like   #6
g026r's Avatar
You can leave the lens on "A". On the left side of the camera mount is a black switch — you can see it in the photo below. Sliding it up stops down the lens, and you then adjust your aperture and shutter to get the needle centered.
Edit: There's a PDF of the manual here: http://www.cameramanuals.org/pentax_pdf/pentax_spotmatic_f.pdf Stop-down metering is described on pages 20 & 21.
08-23-2017, 11:13 AM - 1 Like   #7
timw4mail's Avatar
QuoteOriginally posted by g026r Quote
You can leave the lens on "A". On the left side of the camera mount is a black switch — you can see if in the photo below. Sliding it up stops down the lens, and you then adjust your aperture and shutter to get the needle centered.
Ohh, cool. Didn't know they carried the stop-down switch to the F.
08-24-2017, 05:17 AM - 1 Like   #8
Spodeworld's Avatar
Same here. So you can stop down in camera. Good to know! Thanks
09-01-2017, 01:51 PM   #9
noblepa's Avatar
Unlike the Spotmatic SP, on the Spotmatic F, that switch ONLY stops the lens down. The meter is on all the time. There is no way to turn the meter off. For that reason, a lens or body cap is imperative when the camera is not in use. Without it, the battery will almost surely be dead the next time you wish to use the camera.
09-01-2017, 03:22 PM   #10
timw4mail's Avatar
QuoteOriginally posted by noblepa Quote
Yeah, the Spotmatic F and K1000 are annoyingly similar in that regard.
09-03-2017, 03:59 PM   #11
ChrisPlatt's Avatar
I once had a Super Takumar 55/1.8 lens with "ES" full-aperture coupling mechanism, same as on later SMC Takumars.
It appeared to be factory original, not modified or assembled from spare parts. Perhaps it was a transitional model?
Chris
09-06-2017, 01:18 PM   #12
noblepa's Avatar
QuoteOriginally posted by ChrisPlatt Quote
Chris
There are a few of the later Super Takumars that have the open-aperture couplings for use on the Spotmatic F, ES and ES II. Technically the SMC designation refers to the improved, multi-layer lens coating. It just so happened that the open-aperture metering and the SMC coatings came to market around the same time.
I suspect that the SMC coatings were not quite ready for prime time, when the SP-F was introduced. Rather than wait for the new coatings, Pentax opted to add the coupling to the ST lenses, so they would have something to put on the SP-F. Remember, at the time, Pentax was being widely criticized for sticking with stop-down metering, while most other camera makers had come up with some form of open-aperture metering.
spotmatic camera, takumars on spotmatic
For Sale - Sold: MX, K2's, ME, MZ-7, Program Plus, A3000, Spotmatic, Spotmatic F, S3, Praktica, D-BG3 MightyMike Sold Items 88 12-26-2017 10:20 PM
For Sale - Sold: Takumars, Pentax Spotmatic Sp, Pentax SV with meter Leolab Sold Items 3 06-17-2017 08:58 AM
For Sale - Sold: 5 Asahi Pentax Super-Multi-Coated Takumars Lens & Spotmatic SP II Body / acces jubei951 Sold Items 6 04-29-2009 10:14 AM
Later Takumars? ("Takumars?") Ratmagiclady Pentax SLR Lens Discussion 6 12-01-2008 04:38 AM
All times are GMT -7. The time now is 09:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
