Originally posted by othar I never had any issues with my P30 so I just throw in some random thoughts:
When you say the winder froze: do you mean the lever to wind the film is stuck in position, or are you talking about another camera with a motorized winder by any chance?
Where you using Bulb mode when it got stuck? In that case maybe the shutter button got stuck, push it a few times and it might loosen up again.
Have you removed the lens? If so: is the shutter curtain open too or is just the mirror in the wrong position? If the curtain is open the frozen winder is just a symptom but not a problem, because winding the film during an exposure is not usually desired so it makes sense to prevent this from happening mechanically.
Lever is stuck in position, you can move it out from the closed position ready to start the wind on but no further.
Can't remember what mode I was in but I have tried every shutter speed with no luck. I can see them flashing in the viewfinder as I turn the speed dial and M at the top is always on once the camera is switched on.
I took the lens out and I can push the mirror down but it immediately flips up again. Shutter curtain is closed, the shutter actually fired but the mirror never came down.
CD
