I asked because from what I know, my (now dead) Contax 167MT does read DX, but only for film speed. The rewind is triggered manually, and the camera simply refuses to cock the shutter and advance anymore when the end of a roll is reached (yes the camera has motor wind and rewind built in). I regularly gets 37 to 38 shots on a 36 shot roll with that camera. I know that MZ-M auto rewinds, but am not sure does the DX trigger it or the change in film tension triggers it.
Sincerely
通过我的 Nexus 6P 上的 Tapatalk发言
---------- Post added 01-15-18 at 09:42 PM ----------
Originally posted by Alex645 I canʻt think of any reason why any DX equipped camera wouldnʻt read or ignore the exposure length info on the DX marked cassette. The answer to your question is YES.
Hereʻs a link to DIY DX labels:
DIY Film DX Code Labels: 4 Steps (with Pictures)
And more details about how to de-code DX:
DX encoding - Wikipedia
Just check that the actual amount of exposures on the DX coded cassette matches the DX label. Unless someone DIY the loading of the wrong cassettes with the wrong DX info, you shouldnʻt have a problem.
Originally posted by AstroDave Or, just cover up the bad code(s) (tape or paint over) - or make a new one that matches your film length, and paste it over the bad stuff. I never had a camera that used the codes, but I presume if you had a roll of uncoded film that the camera would work anyhow (you just had to set ASA/ISO and remember when to quit advancing the film).
Yeah that's what the seller suggested if I am in question. The cassettes comes from expired film, and the respooled Vision 3 is taped to the end section of the expired film so the cassettes can be reused without being opened. Therefore there will always be one exposed frame at the end of the respooled film, and the DX code can mean anything but ISO 250, 36 frames.
