Originally posted by pete-tarmigan
There are no electrical contacts between the body and the Winder, only a mechanical coupling (I own an MX Winder). The only contacts you can access without dismantling the winder are between the batteries and the battery holder.
This isn't true. I also own an MX Winder. On the left side of the winder, looking at it as if you are about to use it, there are three small spring loaded pins that make contact with electrical contacts on the bottom of the camera.
As is the case with many other winders and motor drives, if you lay a coin across those three contacts, you can bring the winder to life. A handy way of checking if a winder is still in working order. But to me it sounds as if the OP's winder has an internal problem that's causing it not to interpret the contact pins' signals properly.
