01-26-2018, 06:52 PM   #1
Pentax MX image size
Is it just me or does the MX have a wider image ratio than 2:3?
01-26-2018, 06:55 PM   #2
It has a really big viewfinder, that's for sure. Not sure about its coverage and resulting ratio (should be pretty good, but not 100%), but obviously the film size is standard
01-26-2018, 08:37 PM   #3
Otis Memorial Pentaxian
95% coverage, but the big difference from lesser viewfinders is the magnification of 0.97x. For comparison, the K-1 has ~100% coverage and 0.7x magnification. What that means is that with the MX and a 50mm lens focused to infinity, the relative size of objects in the viewfinder is just a little smaller than what you would see with your other eye. One can test this by keeping both eyes open with the camera in vertical orientation and alternate opening/closing each eye. If the objects are almost life size, the apparent frame boundaries (how big the frame looks) are also larger than with a lesser finder. The MX frame appears about half again bigger than that of the K-1. High viewfinder magnification is the hallmark of most SLRs from the 1970s and 1980s with the MX being among the highest.
01-27-2018, 10:08 AM   #4
I just measured a negative, its definitely 3:2, but my scanner is producing higher ratios that that, around 3.5:2. I'll have to spend some time having a closer look at the instruction manual I guess.
01-27-2018, 10:20 AM   #5
QuoteOriginally posted by Gareth.Ig Quote
Of course all you had to do is measure the physical image on the film to know that the scanner must be the issue as the MX has been a known quantity now for a few decades.
01-27-2018, 03:28 PM   #6
ChrisPlatt's Avatar
The Pentax MX viewfinder image is bigger than practically any SLR or DSLR
due to relatively higher magnification and closer apparent viewing distance.
OTOH "aspect ratio" is a function of the negative size.
24x36mm is standard for all 35mm full frame cameras.
It sounds like your scanner is distorting the images of your negatives.
Chris
01-29-2018, 03:17 AM   #7
nickthetasmaniac's Avatar
I'm confused. Why is everyone talking about the MX's viewfinder when the OP asked a very simply question about image ratio (which has nothing to do with viewfinder)?
01-29-2018, 07:17 AM   #8
cooltouch's Avatar
QuoteOriginally posted by nickthetasmaniac Quote
I think the assumption is that the OP meant viewfinder magnification, even though he asked about image ratio. Of course, the MX being a 35mm camera, its image ratio is standardized at 24mm x 36mm, as are all other 35mm full-frame cameras. But the vf magnification is a variable that can change from camera to camera, so it makes sense to ask about it.
01-30-2018, 01:27 AM   #9
QuoteOriginally posted by cooltouch Quote
Heh, ok - seemed pretty clear to me...
On a tangent, there's no physical limit to a manufacturer making the long side of a 35mm frame as long as they want (as demonstrated by the Xpan family) - are all '3:2' format 35mm bodies exactly 36mm x 24mm, or are there small variations in the frame masking between different bodies?
01-30-2018, 07:56 AM   #10
timw4mail's Avatar
I doubt every body is exactly 36mm x 24mm, but you're probably talking fractions of millimeters.
image, mx, pentax mx image
front element size - does size matter? hadi Pentax SLR Lens Discussion 65 12-24-2017 10:14 AM
Picture file size, picture pixel size, resizeing picture, discussion panonski Digital Processing, Software, and Printing 11 12-01-2016 08:38 AM
Sale of image, requires "20x30 image size digital image" ? NeverSatisfied Digital Processing, Software, and Printing 32 03-29-2013 05:38 AM
Image Size vs Document Size vs Resolution vs Resampling vs ... AHHHH! veezchick Digital Processing, Software, and Printing 13 08-02-2010 03:57 PM
All times are GMT -7. The time now is 09:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
