Originally posted by pres589 Okay, so I've been using Les's XR7 for a few weeks now, and I've had three rolls of film developed by a lab that reviews well. Here are four pictures that I think show where I'm at. I had the lab scan these, I only resized with Photoshop Elements, to show them here.
I shot this one with Fuji Superia 400 with the camera set in A mode. Lens: Kiron 28mm f2.0 @ f2.0
Grain like this on ISO 400 film suggests under exposure - the camera meter will have a minimum EV metering range. If the scene is below this limit, it may simply default to its lowest metering range, therefore not giving enough exposure. Most film cameras go down to about EV 1, a few go down further to EV -1 or so.
Originally posted by pres589 Porta 400, Rokinon 14mm @ f2.8, camera in A mode.
Again the grain suggests under exposure - possibly due to the bright sky compared to the foreground.
Originally posted by pres589 T-Max 400, pushed 2 stops, with the camera set to 1600 on the ISO dial, 0 exposure compensation, A mode again. Lens: Pentax M 50 1.4 @ 1.4.
This is a good image under the circumstances, there is blur (subject movement by the look of it) but this adds to the nature of the shot. The lack of grain at ISO 1600 is very good.
Originally posted by pres589 T-Max 400 @ 1600, A mode. Lens: Pentax M 50 1.4 @ 1.4.
Again, this is likely to be the meter being fooled by the bright high-lights (particularly the large lamp at the top of the frame). excluding the lamp may have dropped the scene below the minimum EV meter range though.
That last one is kind of a good example of what I'm annoyed with. I can improve that somewhat in post-post processing with digital tools... The LCD indication of exposure is really difficult in some of the shots I took as they were taken in dark environments. The camera can drive itself to some pretty long exposure times... The club scene with all of the red is fairly repairable, I was surprised at all of the noise, I assume some of that is from aggressive sensitivity with the negative scanner?[/QUOTE]
Again, this last image is likely to be the meter being fooled by the bright high-lights (particularly the large lamp at the top of the frame). excluding the lamp may have dropped the scene below the minimum EV meter range though. The best I can suggest, is to avoid high contrast scenes and/or place the subjects in more brightly lit areas (the 3rd shot is a good example of this).
The minimum EV metered range is an absolute figure, setting the ISO to 1600 instead of 400 doesn't extend this range as it relates completely to the subject brightness. Beyond this, you're in manual mode unfortunately.
John.
