11-24-2018, 01:51 AM - 2 Likes   #121
Otis Memorial Pentaxian
I am surprised this thread is still stumbling along, but I think it is the nature of things, perhaps. After some additional thought, I considered the fact that I approach my K-3 pretty much the same way I approach even the early 1950s Mamiya Six folder perched on my fireplace mantle. I have never used "green" mode and seldom use "P" mode or auto-ISO. Even when I owned a camera with scene modes, I was never tempted to use them. Manual focus is a friend, not an adversary. All of the cameras on my shelves are basically a light-tight box attached to a lens with provision to produce a controlled exposure of a light-sensitive material in the hopes of creating a viewable image. At the most basic level, they all do the same thing.
Conversely, the last 15 years or so with a digital camera has provided the means to hone the skills from decades of film photography to a much finer edge. Quick feedback is an amazing teaching tool as is the low cost per exposure. There are things I do regularly with digital that I never learned properly with film and my confidence with both is improved as a result (e.g. macro and artificial lighting and long exposures).
11-24-2018, 05:14 AM   #122
Matrix metering of a smart phone is a level of sophistication above a simple light meter, no? I'd think that is one reason.
Though my light meter app is more of a wide spot... it has a movable area where it takes it's readings.
I actually like that approach as it is similar to the meters some of my cameras would have had if they had meters at all, if that makes sense...
-Eric
11-24-2018, 08:52 AM - 1 Like   #123
Two quibbles:
1. A matrix metering app will only work if you can duplicate the field of view (the equivalent focal length).
2. The beauty of matrix metering is that it is usually so good that one does not have to learn anything about exposure. And the curse of matrix metering is that it is usually so good that one does not have to learn anything about exposure! (And thus one has no clue how to handle a black cat on a black sofa.)
With a primitive light meter, one quickly learns that it makes mistakes and subsequently learns a lot about "proper" exposure in a world that is not 18% gray.
My lightmeter app has a field of view zoom. But it won't go really wide. That's not too much of a problem because it doesn't take a lot of skill to pick out a representative part of a scene.
I'd say you still have to learn to compensate with matrix metering just like an old school light meter. DSLRs have EV comp dials, right. If there are 16 stops of light in a scene and say you can typically only capture 10 stops of detail, the matrix meter should do well at picking out the middle better and not be fooled by the things that fool an old school meter. So you will still lose some shadow and highlight detail. But what if the shadow detail was the most import thing in the scene and you want to expose for that. You'd have to bracket or apply EV compensation and know how much to apply which you'd learn from experience like an old school meter.
11-24-2018, 10:49 PM   #124
I don't know whether it's a problem with this thread at the forum server or if the problem lies at my end, but it shows a ninth page that I can't get to. I click on lats page or on the 9 and it always brings me to page 8. Is anyone else seeing this problem? I guess it doesn't matter, because your response will be on page 9 and I can't get there.
Edited to add:
My experiment worked. I was wondering if I posted to the thread, if it would take me to my post on page 9, and it did. Now I can see the responses that I was missing. I'm back in the game now.
11-25-2018, 12:22 PM   #125
QuoteOriginally posted by ctrout Quote
Edited to add:
I get that sort of strangeness every once in awhile here on PF. Short of doing what you did, I have found that closing out the browser and coming back in with a fresh session will usually set all aright.
11-25-2018, 04:30 PM   #126
johnha's Avatar
The problem with matrix metering is you don't know what it has already accounted for (or not) - has it dealt with that bright background behind your subject or does it think you're after another effect and left it as It is? I prefer in-camera centre-weighted or spot as I know what the meter is trying to measure. With an external meter, I use either incident or multi-spot (my meter will record & display 3 readings).
11-25-2018, 05:21 PM   #127
ChrisPlatt's Avatar
QuoteOriginally posted by johnha Quote
Trying to out-think and fight automation is no fun - and a waste of time - which defeats the purpose.
I'd rather make the decisions based on my own experience.
Chris
11-26-2018, 09:32 AM   #128
QuoteOriginally posted by ChrisPlatt Quote
Chris
I've never seen you post a picture. How come?
11-27-2018, 05:34 PM   #129
ChrisPlatt's Avatar
I don't post photos online in this or any other forum for that matter.
Is that required for participation here, or pertinent to this discussion?
Chris
11-27-2018, 08:58 PM   #130
Chris
No just curious. I though you might not have a scanner or something.
11-28-2018, 08:39 AM   #131
With negative film for critical shots I point my Weston at the dark area I want silver in the negative and use the zonal calculator. Matrix metering is a compromise?
accessories, analogy, benefits to film, camera, car, color, composition, contrast, curve, depth, dr, era, exposure, ff, field, film, film era, flash, format, images, insight, mamiya rb, op, photo, photography, photos, scan, shots, sinar, vs
General discussion about 50-55mm lenses - film era. cieslikowski Pentax SLR Lens Discussion 3 05-06-2016 12:42 PM
How much did film bodies and film-era lenses originally cost? Outis Film SLRs and Compact Film Cameras 90 12-30-2015 01:19 AM
Film-era lenses on FF cameras utak Pentax SLR Lens Discussion 5 04-08-2013 02:26 AM
Film Era vs. Digital Era lenses for K-x steveknj Troubleshooting and Beginner Help 23 08-19-2011 05:36 PM
All times are GMT -7. The time now is 09:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
