Originally posted by ZTrev10 Not sure, I'll take a look after my current roll. I inherited the camera from my father, so I'm guessing there's some age to the camera although it's in pretty great shape aesthetically!
---------- Post added 06-03-18 at 07:02 AM ----------
On the 4th row, but on most of them by the number on the bottom of the frame, there's a pretty distinct round corner. Does this signify where along the camera it is?
As has already been said - it's the door seal, upper portion. Replace all of them back there. If they've deteriorated enough for a leak of that size my guess is it'll also be time for mirror-box foam and bumper. None of this is terribly difficult - you'll find a ton of videos on Youtube for instance with various DIY methods (I replace foam in my cameras using 2mm black foam self-adhesive foam sheets that I cut pieces from).
You can also by kits. Search the forum for Jon Goodman's contact info (I can't find it currently) - his kits are perfect. I've used at least 4 of them.
Or the full-meal-deal - you can simply send it to a tech for CLA. (Many here, myself included, rely on Eric Hendrickson at
Home-Pentaxs). An ME will likely run you a bit under $100 for CLA and that will address the foam, the bumper and mirror box, as well as internal lubrication and adjusting of the shutter timings back to proper spec (in addition to every other moving part and surface).
