Originally posted by Qman That makes sense. There's a big gap between those two speeds and once the dial is off it will hopefully stay in that position.
When you say "pull up on the piece that the dial is set-screwed to and rotate until it remains raised", is that to re-set the shaft to the position between 1/125 s and 1/60s?
Thanks!
Yes. It is likely that the shutter dial plate will rotate and drop back down while you are working on the camera. With the top off, you can see that a round plate with slots in it is what determines the shutter speed. It changes the amount of turn (time) before a tab trips the second shutter curtain.
