11-02-2018, 11:44 AM   #1
DOF Preview - Shadowed edges in Viewfinder
I have a very strange experience using the DOF preview on my MZ-S.
When I put a tele or tele-zoom on it and use a higher aperture, and then engage the DOF preview, I can see that the upper edge of the viewfinder has a more or less pronounced shadow. It's not the same with every lens. E.g., with my M 135 3.5, there is absolutely no shadow, even with F32. With my M 75-150, starting from F8 or so, you see it. I first noticed it, when I put my DA* 300 on the MZ-S because there is a very small shadow even with F4 (thought this might be normal since the lens is usable for FF by "chance"). Then I tested the 75-150 and got puzzled.
On shorter lenses, there is absolutely no shadow seen in the viewfinder.
So I wonder if this is normal with longer lenses or something is weird with either the lenses or the camera's viewfinder. Havent used the DA* 300 yet on film and currently no DSLR in the house, so I cant check. But with the 75-150, I never saw an impact on the picture taken.
I mean, it could be a "feature" of the viewfinder. It is not vignetting! Just in case. I am sure about that.
PS: found that somewhere on the internet: "the mirror not attaching to the top of the light box properly and obscuring some of the light from the image circle cast by the lens"
11-02-2018, 12:36 PM - 5 Likes   #2
The top of the viewfinder shows the image from the bottom of the "light box" - as the image is inverted on film. The "shadow" with long lenses is typically due to the length of the mirror reflecting the light up towards the prism. Many SLRs used a mirror adequate for wide to moderate-tele, but would suffer "mirror-cutoff" a bit with very long lenses. Depending on the geometry of the lightbox a mirror long enough to completely avoid this might hit the back element of some shorter lenses, so this was a choice in the design.
The VF cutoff has no effect on the actual picture, just the VF.
11-02-2018, 12:49 PM   #3
Thanks a lot, great explanation!
11-02-2018, 03:07 PM   #4
Alex645's Avatar
I concur with TomB_tx and that this vignetting in the viewfinder with DOF preview engaged and will not affect your actual exposure.
11-02-2018, 03:07 PM   #5
nickthetasmaniac's Avatar
QuoteOriginally posted by TomB_tx Quote
Getting a bit OT, but is this why the later Hasselblad 500 series bodies had a floating mirror assembly?
11-02-2018, 03:30 PM   #6
QuoteOriginally posted by nickthetasmaniac Quote
Yes, and a few 35mm bodies also used a linkage that moved the mirror back as it moved up to allow a longer mirror.
11-02-2018, 10:35 PM   #7
Otis Memorial Pentaxian
My Ricoh XR7 has an articulating mirror as does my Minolta SRT-101.
da*, dof, dof preview, lens, lenses, mz-s, preview, preview shadowed edges, shadow, viewfinder
Nature Shadowed JNic66 Post Your Photos! 2 08-15-2018 07:18 AM
Strange behavior K20D .. no DOF preview, no aperture stop down - but works ok on 'A' kayakfari Pentax DSLR Discussion 3 03-19-2017 10:23 AM
How to make sense of the DOF preview/Optical preview on the on/off dial ? photoleet Pentax K-5 & K-5 II 5 04-17-2012 04:22 AM
Black & White Shadowed Flower Sailor Post Your Photos! 9 06-09-2011 05:42 AM
Autofocus: Horizonal edges ≠ Vertical edges ... normal? aerodave Pentax DSLR Discussion 3 10-26-2007 08:08 AM
All times are GMT -7. The time now is 06:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
