Originally posted by LesDMess If you unplug the flash from the port and plug it back in, does it fire again? If so, then it sounds like the port is shorted closed and not opening.
If that were the case I would think the flash would go off again as soon as it was recharged. FWIW if I plug in a flash that's turned on and charged into the working PC port of my K1000 the flash goes off. This is not the case with my Minolta X700 and Pentax Program Plus. I'm pretty sure the manuals though advise you to have the flash off before plugging in. I seem to recall some (not all) of my flashes would trigger when you first plug in the PC cable to the flash - should I be foolish enough to have it turned on.
Either the PC connector needs cleaning, is bad or there is a fault in the wiring or switches internally.
You can download a Spotmatic Service manual from here:
Pentax Manuals
Or purchase the entire series and motor drive service manuals from here:
PENTAX SpotMatic, SpotMatic II, SpotMatic 500, Spotmatic Motor Drive Series Service Manual
