Originally posted by RedRuff Hi, my brother uses an ME Super and suffers from dark bands at the bottom of some pics. He uses various 200 and 400 asa Fuji/Kodak films then sends them off to a photo lab to be developed. About a third to half of his pics have this dark band at the bottom, as if the shutter is sticking somewhat, and one or two pics on his roll mysteriously vanish.
I looked at it using Bulb setting across various lenses and apertures to see if it sticks and it seemed fine. We then shot a roll of black and white at every shutter speed and they were all fine. He doesn't take notes on the settings he used so we can't pinpoint anything specific.
He did drop his camera before this started happening... Is there a specific part that may have suffered? I've un-jammed a couple of these before already but haven't delved past taking the electronics out the top!
Cheers!
By bottom, do you mean the bottom of a horizontal frame in normal orientation (sky at top)?
Three things come to mind. Either the mirror is not fully flipping out of the way and is casting a shadow...
-- or --
...a shutter curtain travel problem that defies easy description (IIRC, the shutter moved top-to-bottom. Simple capping would result in a darker sky in that case.)...
-- or --
...the front of the everready case is intruding into the frame.
Take the lens off in B mode and observe the mirror movement for several cycles.
