Originally posted by monochrome Be sure to check that the LX Winder drive pins are engaged to the bottom of the film take up spool on the camera. If the coupling is correct and the winder is spinning the drive plate / pins, the take up spool needs adjustment. I would send the LX and the offending winder
together to your repair specialist (or to
Eric Hendrickson) for a diagnosis.
As I've posted in
Pentax LX Damaging Winder Attachments? - PentaxForums.com, my second winder from KEH failed in a very wired way:
- Upon installing, the winder correctly advanced film
- Shutter got triggered when pressing the shutter button
- The aperture stopped down
- However the mirror did not raise
- Moving into MLU causes the shutter to fire
- The motor drive seems to be dead after that - no LED flicker, no motor movement etc.
- But the camera is functioning correctly after this point and I'm still contacting Advance Camera about this issue.
KEH can't figure what happened and refunded me the winder, though.
---------- Post added 12-12-18 at 07:43 PM ----------
Originally posted by cpk How are you using your LX? I have both the LX and the MX, complete with winders. I am using the LX for street photography without the winder because of the weight it adds and, to some degree, its noise. For me the LX's metering system is ideal for my purposes because I can set the f-stop and the LX chooses the shutter speed depending in the lighting situation at the moment. If I were to use the MX for street photography, I would have to re-meter each time the lighting situation changes. However, if I were to use the MX, I would use it with the winder because it makes it easier to hold (I have the side grip on my LX).
I usually shoot it in A mode, especially if I'm using slide film. I also like the FB-1/FC-1 combo because I have severe near sight problem and I have to wear glasses when using a camera. However I don't mind a full manual camera because I've used my Spotmatic F with very good results. A Spotmatic F or KX with motor is one of my dream cameras.
I bought the LX mainly for the IDM meter, because I like the new Ektachrome very much and I want a camera with precise meter for that. A lot of of my photography subject is on trains and railroad, so the ability to shoot continuously comes very handy, though I have used my Spotmatic for this task from time to time.
Reason: fix typos
