G’day and welcome to the forums 😊 That’s a wonderful Spotmatic you have inherited!
Originally posted by gloco I have this Asachi Pentax Spotmatic F passed on to be my father. The camera has a problem which is the battery does not work so I cannot use automodus but it works well manually.
The Spotmatic F is a fully manual camera and does not have any auto modes. Even if the battery works all it does is power the light meter - you will still need to manually change the aperture and shutter speed.
Quote: Now I have a question regarding the self timer. I pressed the self timer downwards and when i press the little button it doesn't move. Is the self timer also reliant on a battery or is it simply stuck? Please see attached pic
The self timer is mechanical, so it doesn’t need batteries. On older cameras that haven’t been used in a while it’s common for self-timers to get gummed up and fail through lack of use...
