Originally posted by BarneyL Hello everyone,
It seems my Super A has developed some film advance issues. Starting more or less half into the roll, advancing becomes less and less smooth. It's been always this way though, and I've considered that normal, until on recently developed film I noticed few overlapping frames.
Did anyone else here had similar problems with this camera? Is this something that can be fixed with some amateur-level DIY, or does it require specialized care and/or parts replacement?
The supply reel shaft might be binding. If you have access to some molytone grease or graphite-based lube: between rolls of film, lift the rewind knob up almost to the point where it would open the film door, apply a little grease around the base of the shaft using a toothpick, press the knob back down into place and spin it a little. You might need to repeat the process a couple of times.
"Your mileage may vary" but this was all that was needed to make my MX film cam stop overlapping frames a few years ago.
