Originally posted by Ediz7531 Oh, the blog posts I saw implied you need to disassemble the plastic housing to put the dial back on, but your hypothesis makes sense. The eyepiece ring also had two tiny holes on either side of it, so I'm guessing a lens spanner wrench would work well there too.
I've had some luck using small pointy things to unscrew a part that would otherwise have needed a spanner I didn't have, you got to go gently though and make sure they are well seated in the holes, especially if it's a soft metal like aluminum.
