Originally posted by Rolfsson The problem is with the Exposure Compensation dial on the LX.
The ASA dial moves fine separately from the compensation dial but when i want to ONLY move the compensation to anything higher than 1x, it wont go there. it stays stuck at 1x. however it will move down all the way to 1/4..
Is this purely a mechanical problem? or could there be something else involved?
Just to be sure, in order to move the compensation dial off the center (1X) position, you have to press the DIAL LOCK RELEASE BUTTON as shown in the Pentax LX manual. With that button depressed, you can move the compensation to 1/4X or 4X position.
There are exceptions to this. If you have the ASA set to the lowest setting of 6, you cannot move the compensation to 4X but you can move it to 1/4X. If the ASA is set to the highest at 3200, you cannot move the compensation to 1/4X but you can move it to 4X.
