Originally posted by evilash1996 The camera is setup correctly and I am definitely in the meter's range. I am only using 400 speed film so it should all be working correctly. There is definitely something malfunctioning with the camera.
That last is possible, though a few tidbits of information might be in order:
- Your meter has a limited range of linear sensitivity
- Using faster film does not increase that sensitivity
- When light levels are above or below the linear range the meter may provide readings indicating more or less light than what is actually there or unexpected "dipping" of the meter needle.
- Readings with a spent battery will be unreliable
Something to consider:
The Spotmatic is cool in that it provides a visual indicator of when the meter is outside its linear range. The triangular index for the shutter speed is red rather than black, the meter readings are probably not reliable. Set the ASA at 400 and note that the index goes red at 1/2s. Put ASA at 64 and note that it goes red at 1/1000s. The user manual includes a table showing the accurate meter range by shutter speed and film speed. The location varies, but the page is generally headed, "Range of Light Measurement" or similar. The table mirrors the behavior of the shutter speed index color though with additional information.
That being said, it is probable that there is a problem with the meter circuit that may require replacement of parts.
