Hi!, lot of time has passes, and lock down.
On lock down I decided to dismantle it until final consequences.
And I do
I manage to fix the problem, but I’ve had another one.
Cleaning the interior mechanism on the left side of the mirror, I dropped some isopropilic alcohol in the mirror, and I clean it with a cotton stick: error!! I killed it!, so I replace ir with another used one. So take care with screens and isopropyl alcohol.
I’ve cleaned with zippo fluid the mechanism on the left side of the mirror, and then I lubricated it with watch oil ( a good Swiss one).
And voila, problem solved.
I dismantled a lot, and I was in need to desolder some cables, keep track with pictures
in the picture marked the area where i cla'd.
Good luck if someone's try it!
Hope it helps!
