Originally posted by Ontarian50 110 film doesn't use the sprocket holes for winding the film. The film leader is attached to the takeup spool, which is driven by the camera. The little holes in 110 film were spaced one per frame, and the camera stopped winding when a little pin popped through the hole, confirming you were at the next frame. That pin retracted when you clicked the shutter, allowing for the film to wind again.
The problem with using cut down 35mm film for 110 use, is you would have too many holes.
Oh...I did not know that. I knew the drive was in the center of the take up spool but I thought the gear turned on the sprockets until it rotated enough to stop the frame. I didn't realize the one sprocket hole did the work. Oh well....
---------- Post added 05-08-19 at 01:24 PM ----------
Originally posted by UncleVanya Reading online it was common to use 16mm movie film to reload the cartridges. These like 35mm have holes.
I did use 16mm for Minolta 16. I had a 50 foot roll and probably used less than 10 ft of it...
