Hello,
Heiland was Honeywell's division that imported Pentax to the USA during the 60s and 70s. This is a Honeywell Heiland Pentax H3, simply known as Pentax S3 in the rest of the world. I believe this was the first camera to feature full auto diaphragm that allowed wide open focusing and composition and when the shutter fires a bar pushes the lens pin to close to the set aperture. I've been doing research and this camera was introduced in 1960, but production apparently started in April 1961. Some sources say it was produced until 1962, others cite 1963. So it was in production for no more than 2 years. According to research, very early samples had a max shutter speed of 1/500 but quickly changed to 1/1000. With this camera, the clip on Asahi Pentax meter was launched. The camera had a notch in the shutter speed dial to mechanically sync with the meter. Earlier samples did not have the notch.
I found this tired puppy wandering in the marketplace so I adopted it.
This particular sample has a max speed of 1/1000 but no notch in the shutter dial. So this makes it an early sample, circa 1961.
It was very tired when I received it so I took it to my workbench and did a deep cleaning without taking it apart. Shutter fires and speeds sound about right from 60 to 1000. At low speeds (less than 60) the shutter sticks sometimes. But after a few tries it seems to improve ever so slightly.
As you can see there is a small dent on top of the prism but it is purely cosmetic. No effect in operation. By the wear marks it seems a clip on meter or maybe a cold shoe lived there for a while. The mirror was cleaned. There is minor dust in the prism/focusing screen but nothing major.
So here are pictures of it Before and After:
BEFORE:
AFTER: (Yes, it is the same)
Ready to see the light again!
Dry testing was promising. Auto aperture works properly. Can't wait to use it! I'm currently testing the Revue ML (Praktica MTL5B) but after that I want to use this one.
My Pentax SV will be sent to Eric for a CLA. Depending on how much it goes I may send this one later.
What do you think?
Thanks,
