10-05-2019, 07:44 AM   #1
My new Pentax Spotmatic F (SPF)
I received yesterday my new SPF, with SMC-Takumar 50/1.4, near mint condition, with operating meter.
Using a SR 44 battery (1.5 volts) I compared the mettering with my K-5ii in center weighted mode:
SPF: f8 and 1/125s (iso 100)
K-5ii: f8 and 1/500s (iso 100)
Difference of two stops.
Do you think that the SPF meter is defective?
SM-N910C  Photo
10-05-2019, 08:08 AM   #2
boriscleto's Avatar
No. The SP F used a 1.35v Mercury battery. It does not have a bridging circuit.
There are several solutions, Wein cell batteries, a simple adapter for PX75 hearing aid batteries, a battery adapter that lowers the voltage etc.
10-05-2019, 08:34 AM   #3
tonyzoc's Avatar
QuoteOriginally posted by dantonvb Quote
I've got an SPF and I get similar numbers with the SR44. The camera circuitry is supposed to knock the voltage down but doesn't seem to. I used an adapter with the 1.55v batteries and it gets closer but not perfect. I usually shoot B&W so I use the meter, under expose a little, use the sunny 16 rule...negatives come out fine. Unless you're shooting Ektachrome, you should be fine.
10-05-2019, 08:58 AM   #4
MossyRocks's Avatar
My understanding is that it is a balanced meter so the voltage doesn't matter much so long as there is enough to run the meter. I've been using 1.5v 625 batteries in mine for the last 20 years without issue.
10-05-2019, 11:18 AM   #5
That looks like new. Congratulations.
10-05-2019, 12:17 PM   #6
boriscleto's Avatar
QuoteOriginally posted by tonyzoc Quote
QuoteOriginally posted by MossyRocks Quote
The original Spotmatic, and the SP II, were not voltage dependent. The SP F is.
10-05-2019, 02:27 PM   #7
ChrisPlatt's Avatar
aohc.it website states:
According to information from Gene Poon from Spotmatic discussion group such 1.35V voltage cells can be replaced in the Spotmatic series cameras with any matching 1.5V battery (silver oxide type are good). That's because original SP, SPII, SPIIa, SP500, SP1000 all use a bridge circuit where the meter measures the balance between the two legs of the bridge. Both legs of the bridge would be equally affected by any "normal" voltage variations. SPF uses a dual coil meter, the two halves equally affected by any voltage variations.
pentaxuser.uk states:
SP F.
• Mallory PX625, Duracell PX625A, Excel Z625PX, Eveready E-625N.
• The Spotmatic F uses a dual coil meter movement that, like the bridge circuit, cancels out battery voltage variations on the level we are dealing with here. So it is immune to the difference between 1.35v and 1.5v, too. The original battery for the Spot F was a mercury type. In this case, Pentax used the identical circuit in the KM and K1000, without any electronic changes. They substituted the silver types with NO ALTERATION at all.
My SP-F had been serviced by Eric Hendrickson before I ever used it. He is the person I'd trust to know best whether adjustment is normally required.
Chris
10-05-2019, 02:32 PM   #8
That is a very nice looking spotty
and thank you all for the battery information.
here is mine
10-05-2019, 03:08 PM   #9
Otis Memorial Pentaxian
Are you using the same lens on both cameras? If so, it is likely that the K-5II reading is the larger part of the problem. Do the comparison with the K-5II attached to a lens where the camera is able to control the aperture. Stop-down metering on the K-5II is not bad, but also not reliable.
Secondly, did you remember that the SP F does not require diaphragm stop-down to meter when used with an SMC Takumar lens? The meter switch should be in the OFF (down) position and the A/M switch in the A (auto) position such that your SMC lens is wide open to meter.
There is also the chance that the coupling mechanism on the body, particularly alignment of the tab for lens orientation that engages the boss on the lens rear, is not proper.
It is also possible that the SP F's meter simply needs adjustment.
I hope this helps.
10-05-2019, 03:12 PM   #10
QuoteOriginally posted by ChrisPlatt Quote
SP F.
Chris
Thanks for adding this to the discussion. My experience is that the SP F is not voltage dependent.* The circuit diagram also indicates such. That being said, I do use an MR-9 adapter for convenience, if nothing else. My SP F meter agrees well with my K-3 both for open-aperture and stop-down aperture measurements. If one is uncertain regarding voltage, the MR-9 adapter + SR43 cell is a very workable and cost-effective solution.
Kanto Camera (Japan) | MR-9 (voltage stepdown)
(...no relation to Kanto Camera except as a satisfied customer...)
* I have three cameras that take the PX625 that do not have a bridging circuit and the difference is obvious with and without proper voltage.
10-07-2019, 07:15 PM   #11
First of all congrats on that good looking camera.
I recently got another SPF which is currently being serviced by Hasegawa repair.
Just to add on the battery discussion, he did test the meter using a regular 1.5v cell and a rubber band. I believe the battery should be fine, so the meter might need an adjustment if you cant discard other reasons.
f8, iso, k-5ii, meter, pentax spotmatic, spf
For Sale - Sold: Black Spotmatic F, Silver Spotmatic F, Pentax AP, H1a, SV MightyMike Sold Items 36 02-11-2013 07:21 AM
All times are GMT -7. The time now is 03:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
