Originally posted by 35mmfilmfan I keep one with Trebor Extra-Strong mints in, as the paper packaging is non moisture-proof, and also disintegrates when stuffed into a pocket. I tell people the mints are Horse Tranquilizers ...
So where do you keep your horse tranquilizers? Mixing those up would not be a good mistake to make
My daughter likes to make tiny flower vases out of them.
25 or so years ago, as a prank at work, colleagues would invert a can of "canned air" and spray a bit of the cold gas into a canister (Fuji ones worked the best).
Then, they'd snap on the lid, set the canister on the counter, and walk away.
A short period of time later (though hard to predict), the gas would heat up and expand, sending the canister flying across the room with a satisfying "pop!"
That's on the list of things to not do to the significant other...
-Eric
