Show Printable Version 6 Likes Search this Thread
10-16-2020, 08:15 PM   #16
QuoteOriginally posted by g026r Quote
Just going from memory, since it's been a while since I owned a Jupiter-37A, but you should be safe:
  • It's a manual aperture lens, so no aperture pin to worry about.
  • The rear element is a fair distance up the lens body itself. Since nothing sticks out beyond mount threads, there's nothing to interfere with the open aperture linkage.
thanks for the reply.
i did notice that there was no pin, nothing to interfere, so i screwed it on until it stopped and so now i must harken back to the sunny 16 days of yore, or invest in a light meter
10-16-2020, 08:17 PM   #17
i did notice that there was no pin, nothing to interfere, so i screwed it on until it stopped and so now i must relearn sunny 16 or buy a hand-held light meter
10-16-2020, 08:20 PM   #18
thanks!
10-17-2020, 09:57 PM   #19
Otis Memorial Pentaxian
QuoteOriginally posted by cigardoc Quote
Stopdown metering will work, you just need to stop the lens down manually using the preset lever and the meter switch on the side.
11-01-2020, 08:49 AM - 1 Like   #20
I have two helios 44, 58 f2. One will fit my spotmatic F but the other (apparently the same lens) won't. Don't try to mount a smc takumar in a zenit, the small pint in the lens will catch in one of the recessed screws of the mount and you will have an interesting problem: how to unmount it.
02-14-2021, 11:55 AM   #21
QuoteOriginally posted by wupdigoj Quote
I just noticed this post. Thanks for pointing out this problem that might potentially affect owners Zenit and other brand bodies where the screw recesses on the mount may be larger than on the Pentax bodies. I am not sure, but my Mamiya/Sekor 1000 DTL might be vulnerable!
a/m, aperture, coupler, lens, lenses, mount, pin, position, spotmatic, switch
Question Spotmatic ES Reviews Page : lens compatibility note stevebrot Site Suggestions and Help 3 07-21-2019 08:41 PM
K 1 ll and third party lens compatibility. Terry C Pentax K-1 & K-1 II 10 05-15-2018 07:27 AM
Third Party Lens Compatibility - M42 Mount pendennis Pentax SLR Lens Discussion 14 12-27-2017 06:49 AM
ES / ESII case womble Film SLRs and Compact Film Cameras 2 01-06-2014 04:59 PM
Older third party flashes and Pentax P3 compatibility CanadianPhotoLuddite Film SLRs and Compact Film Cameras 6 04-23-2013 01:56 PM
All times are GMT -7. The time now is 01:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
