Originally posted by tonyzoc What's the best (cheapest) way to buy chemistry?
In my opinion the best way to go about this is to find a good chemical supply company and brew your own developers.
Originally posted by Alex645 The actual ingredients:Kodak D76:Sodium sulphite (7757-83-7), Hydroquinone (123-31-9), Bis(4-hydroxy-N-methylanilinium) sulphate(55-55-0)Clayton F76:Potassium Metabisulfite (16731-55-8), Potassium Hydroxide 1310-58-3 2-5
The fun thing with making your own "D-76+" is when you alter the ratios of the ingredients you can figure out which component chemical does what - and from then on you can experiment with the ratios of the component chemicals and figuring out working dilutions and process timings that deliver exactly the right contrast and tonality that you want and you can a set in motion a highly refined developing process of your own. As a rule, scanners work best with lower contrast negatives*. When shooting with the ultimate intent to scan expose for the shadows and develop your film for the highlights.
Personally I work with Pyrocatechol based developers, pyro [1,2-Dihydroxybenzene] developers are simple enough to make**. PMK developers stain negatives and the degree of stain is influenced by density. So when images are scanned the stain acts like a contrast mask and helps control the dynamic range of the resulting scan.
* Also the choice in scanner plays a significant role in this, cheap scanners have sensors that can only handle so much dynamic range and produce scans with below average levels of sharpness. More expensive scanners can have truly massive dynamic ranges and high sharpness - you get more exposure leeway with the more expensive product, but when the stars align you can get truly stunning scans.
** just be
careful when handling
Pyrocatechol.
