Originally posted by tuco you can use filters on the enlarger to effectively "burn" and "dodge" shadows and highlights with variable contrast paper.
A handy trick indeed, however the OP here has expressed a desire to produce negatives suitable for scanning. The equipment needed for optical printing takes up a lot of space, and demands a physical environment [light tight dark room & film safe lights] that only hardcore enthusiasts* and professionals are willing to attempt these days.
* ..foolhardy amateurs..
---------- Post added 2019-12-19 at 01:33 AM ----------
One thought I have had regarding increasing the longevity of developing concentrates is the possibility of crystallizing the solution in order to preserve it. Depending on environmental factors it could be quite easy to get it to take on a crystal form and later on, re-hydrate it to make the required developing solution. The biggest problem I can see with this approach is the exposure to atmospheric oxygen causing depletion of the developer and also the development of undesirable polymorphs* that could change the properties of the developer.
Originally posted by Alex645 I am not a chemist but I do not believe that is equivalent to the Bis(4-hydroxy-N-methylanilinium) sulphate listed in Kodak's MSDS sheets for D-76.
Just for reference Sodium tetraborate decahydrate [Na2B4O7] - is
exclusively referred to as borax, which appears in many published recipes for D-76**.
*certain substances when crystallized can have more than one crystals form, sometimes the chemical and physical properties of the Alpha crystal form and the Beta form can be markedly different. These changes in crystal structure can affect a number of things such as the compounds solubility in water.
** Though to make the issue murkier, there are numerous variants of the classic D-76 recipe.
