Originally posted by ismaelg Hello,
I have a dedicated thread on a K2 I'm trying to restore. But I want to ask here for more visibility. The take up spool is not moving with the advance lever. The shutter cocks and if I move the sprocket gear with my finger, the spool moves.
The rewind knob is not depressed and it "seems" to be working.
Any ideas on how to proceed? Online resources are very hard to come by. I'll I got was a short service manual that really doesn't help much.
Thanks,
I have a black K2 with the same issue. I'm not finding anything causing this under the baseplate. What I suspect is something under the top plate winding gears is not engaging...like a spring positioned gear that might not be sliding into position...or something similar...maybe a lose screw blocking something. I haven't taken the top off yet but I plan to. I actually bought this K2 because I have a black one that works perfectly, but is a bit ugly...brassing and dings, etc. I was looking for a clean black body for parts. It turns out the one I got wasn't that much better looking so if I can fix the winding issue I'll just keep it as is.
