Originally posted by lonerider41life Hello.
I bought this camera under 10 USD, from a flea market (I don't know if working). Have someone any info for this camera? User manual from somewhere or for anything like that? Thank you.
If it is working, then you have a bargain.
Pentax Z-5p - Pentax Autofocus Film SLRs - Pentax Camera Reviews and Specifications
The Z5-p is an underrated model in the Pentax film-era line-up. It has screwdrive autofocus, a shutter that goes up to 1/8000th and a high flash sync speed of 1/250th. It also features a panorama mode that you access by sliding a lever on the back.
Getting a manual is difficult. I believe the camera was originally intended for the Japan market only. The manual can be found on the Internet, but is in Japanese. That said, the controls and program are like an early version of a Pentax DSLR, especially in the Hyperprogram mode. It isn't too hard to figure out.
You will need to find 2CR5 batteries for the camera and drive. There is a separate battery for the data back. I can't remember which size you will need but the correct type should be engraved on the inside of the camera.
Pentax Z 1991-2000 - www.pentax-slr.com has more info.
