Originally posted by Wasp Operating this big boy is not for the faint of heart. I am trying to picture what the drill was. Here is my best guess about the challenge facing the Graflex guy one century ago. Feel free to fill in the missing bits.
A few notes:
Quote: 4. Cock shutter
5. Lower mirror
First, you'd want to make certain the camera is in instantaneous mode. (The manufacturer-recommended order of steps for setting the shutter is different when you're in time mode.)
Assuming you are, you'd then lower the mirror before setting the shutter; you can't wind the Graflex SLR shutters in instantaneous mode unless the mirror is in place. This is to prevent accidentally exposing the film while you're winding. (Speed Graphics have no such safety mechanism on their focal plane shutters; ask me how I know this.
Once the mirror is in place, you'd go about setting the shutter. This is a two step process:
- Set the shutter width. This is the knob on the top back corner.
- Set the shutter tension, which controls how fast the curtain moves. This is the knob on the bottom back corner.
The combination of shutter width & shutter tension gives you the exposure time, which can be checked on the plate over the lens.
Quote: 12. Focus your f/11 or f/16 lens - f/8 lenses were probably considered fast in this era
13. Wait for the decisive moment
There's a good chance the lens is f5.6 or even f4.5. Graflex tended to use fairly decent lens speeds, since they were intended for press use. (I'm certain being Kodak's professional equipment division during much of this period helped in that regards.)
There should also be a step 12.5 in there: set the aperture.
Since AFAIK only the very late models released after they had discontinued 5x7 cameras had any sort of semi-automatic aperture control, you'd want to leave setting the aperture until the end in order to prevent the focusing screen from getting too dark.
