Originally posted by choonie Seems like its not bad, the felt looks orderly. I couldn't slide any paper into the hinges
Obviously you are in a better position to judge but from your photo, that felt seal certainly isn't new and it looks quite worn to me. Given that the light leak seems to be the same width from top to bottom, it seems to suggest that the hinge seal would be the most likely cause. On the first photograph that you posted, there is quite a wide area of light damage but you can also see several smaller strips of damage which would have happened as the film was advanced. It doesn't look like a shutter problem to me.
Why don't you put another roll of film in and then tape up the rear camera door, just to diagnose the fault?
