Show Printable Version 15 Likes Search this Thread
11-09-2020, 02:52 AM - 1 Like   #16
LX has fantastic registration and the ability to go back several frames and then keep registration, highly recommended
11-09-2020, 05:02 AM   #17
Not a Number's Avatar
The Minolta MD/7/11 and XE-7 have a multi-exposure function.
I'm not sure if the MD-5 has the function. The above bodies the film does not move, no need to tension and hold the rewind knob so frame registration is maintained. The tension and hold technique always has some slippage in my experience. You need to keep track of the additional frames yourself however.
11-09-2020, 05:37 AM   #18
K1000...
Kirk B.
11-09-2020, 08:56 AM   #19
UncleVanya's Avatar
I did them on my Nikkormat but the F2 was more advanced and accurate and if you needed to shoot multiple shots and then return to a previous shot... So workflow like:
Shots 1-6 normal, then go back to 3 after moving to new location, shoot multiple exposure in shots 3,4, & 5. Skip over six, shot 7-12 normally, back up to 11 and add multiple exposure.
Obviously this isn't commonly required. And it takes planning and jotting down notes.
11-09-2020, 09:00 AM   #20
Minolta Maxuum 7 and 9.
11-09-2020, 01:09 PM   #21
Beginner question about double exposures....do you expose both images normally or do you underexpose each a bit? Seems like 1 normally exposed image on top of another would lead to a very overexposed image.
11-09-2020, 01:52 PM   #22
The first 35mm camera I ever used could do that. A hand-me down from my grandfather - the Kodak Signet 35 rangefinder. It had a little lever on the back for double-exposures. You pushed the lever when you cocked the shutter. Since it didn't involve the winder at all, the film stayed in perfect registration. I had a lot of fun with that camera in high school before I progressed to the Pentax K1000. It took great pictures. In fact I won my first high school camera club photo contest with a black and white print taken with that camera.
---------- Post added 11-09-20 at 03:54 PM ----------
QuoteOriginally posted by Lhorn Quote
You need to underexpose both shots by 1/2 to 1 stop.
11-09-2020, 01:55 PM   #23
titrisol's Avatar
Location: In the most populated state... state of denial
The Nikon FE-FM series does it very well
Pentax LX, and MZ6/7/L from what I know
11-09-2020, 06:39 PM   #24
UncleVanya's Avatar
It depends on how many total exposures you use. If only two then as stated by another response 1/2 to 1 stop depending on the subject. The two exposures don't have to be equal if you want a different effect.
11-09-2020, 08:01 PM   #25
Ricoh XR-1, XR-1s,XR-2, XR-2s, and XR7...all Pentax K-mount.
Addendum: The Ricoh cameras that have the double exposure feature are easily told by looking for the button on the back of the top cover just below the wind lever.
I tried on ME and MX, could never get the frames line up correctly, I heard changing bag is needed.
Ricoh KR-5 Super II and 1st generation of Chinon SLR I can get cheaply, does those do multiple exposure well as well?
11-09-2020, 08:58 PM   #26
Otis Memorial Pentaxian
QuoteOriginally posted by Angelic Layer Quote
Many cameras will allow cocking the shutter without advancing the film by simply pressing the release button on the bottom of the camera. Models that support multiple exposure as a feature (many models discussed above) are not uncommon and will address that feature in the user manual. You may find the page below helpful as a means to research whether a camera you are interested in provides that function as a supported feature.
Camera Manual Library
11-10-2020, 03:23 AM   #27
LennyBloke's Avatar
QuoteOriginally posted by garywakeling Quote
Totally agree - best I'd seen back in the day
11-10-2020, 04:51 AM - 1 Like   #28
Thanks
---------- Post added 11-10-20 at 05:54 AM ----------
I have a KR-5 Super II and almost certain it doesn’t have a special feature to do double exposure except as mentioned above, hold the little button on the bottom of the camera while you wind the film advance
---------- Post added 11-10-20 at 06:00 AM ----------
From Butkus.org
“ Simple, dependable construction
The straightforward, mechanically oriented operation of the KR SUPER II also makes it ideal for certain types of special photography. Once feature useful for astro- and microphotography is the unique action of the mechanical self-times - the mirror and lens lock up about 10 seconds before the shutter opens, so any vibration has a chance to dampen out completely. Multiple exposures are also possible, by disengaging the sprocket drive with the rewind button before using the manual advance lever. And, of course, full manual control of focus, aperture, shutter and ISO settings gives you unlimited freedom to experiment.”
11-11-2020, 02:58 PM   #29
womble's Avatar
One classic technique is to photograph something against the sky, setting the exposure as for the sky rendering the main feature as a silhouette, more or less. Then photograph something else without the bright contrast at the metered reading. This will leave you with the second thing nicely exposed within the original silhouette surrounded by a lighter "over exposed" region. Part of the fun with double exposures is the serendipity of them.
11-11-2020, 06:50 PM   #30
tonyzoc's Avatar
I have done double exposures with Exakta cameras. You can cock the shutter by turning the shutter speed knob. Also I've got a cheap Seagull TLR 4B which allows you to cock the shutter without winding... unfortunately I probably made more unintentional double exposures with it than intentional. I think the Pentax PZ-1 also does multiple exposures but I've never tried it on that camera.
35mm camera, advance, button, c3, camera, exposure, exposures, feature, film, frame, half, ii, image, lever, light, meter, nikon, post, rangefinders, rewind, rollei, school, shutter, slr, underexpose
Abstract Double Exposure brieck Post Your Photos! 2 10-15-2019 02:36 PM
Double Joy, Double Trouble louparker Monthly Photo Contests 6 11-11-2018 04:05 PM
Nature Double Double-banded plover groom Kailash Photo Critique 3 02-04-2011 01:20 PM
Metz 48 AF1 not firing as reliably as AF360 skid2964 Flashes, Lighting, and Studio 0 01-28-2009 06:51 AM
P30T, shutter will not reliably stay open on bulb with cable shutter control. skid2964 Film SLRs and Compact Film Cameras 6 06-09-2008 08:04 AM
All times are GMT -7. The time now is 02:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
