Originally posted by stevebrot Let me get this straight...two different lenses don't register properly for aperture display on your camera. Regardless of how well your Tamron works with your ZX-L, the fault likely is with the body or how it is being used. Assuming this happens when attempting to use the aperture ring in other than the "A" position with those two lenses, the answer might be found in the ZX-L manual. Page 64 says that when using the aperture ring, the displayed value is an approximation and may not agree with the value set on the ring.
The settings I've set up on the ZX-L has been the same since I've got it, even when Ive used older manual lenses on it and hasnt caused my any issues until now that Ive tried those two Macro lenses on it. Like I said, the Tamron lens works perfectly with the camera.
So I shouldn't worry about the fstop on the display being a bit off from the lens fstop?
