Originally posted by tonyzoc I was looking for my Charger Pack M today, and while I didn't find it, I did find my Data MX back. It's missing the optional cable and Watch insert. I used to carry the watch insert like a pocket watch and lost it somewhere. I also found 2 rolls of Lucky brand 120 B&W film...expired in 2007. I'll still try shooting it.
I am looking for a MX with that Data back. Do you also have the dedicated MX body to go with that back?
On the rebuild topic: guess you've seen this:
Digital Image Studio, Pentax Ni-Cd Battery Pack LX refurbishment
I also know that there are some companies that provides custom made battery "racing packs", they could make those 7.2V stacks ready.
Charging the pack using those 500mAh batteries could take as much as 24 hrs. It might be an idea to get cells with less capacity to cut down on charge time. Heat emission might also be a problem in that closed compartment inside the battery pack, especially during charging. Heat emission during charging is due to internal resitance within each cell, and also additonal resitance from the soldred connections and leads. Simple calcualtion would be V x I = W: 1.2V x 500mAH = 600mW x 12 cells = 7 200mW, i.e 7.2 W per hour x 24 hours = 172.8 W heat needs to be transported out of the casing. That is lot more than it was designed for (110mAH cells). Now I am not a battery expert, and this is a very rough estimate taking away many of the parameters, but it might be something to think about during the rebuild? ( I also know that Ohms law might not work properly for battery recharge calculations, so.. it is what it is: just a suggestion to that you do take this into your consideration.)
