Dear Forum
Today a rare Pentax arrived, with a lot of help from a fellow forum member. The camera is the Asahi Pentax Spotmatic II Data II. The camera was a special order, made between 1971 and 1973. I do not have any information about how many of these were made.
The same data back was also available for Spotmatic and Spotmatic SP F and the ESII. The SPF and ESII even had a MD option. Later a similar data back was made for K2 DMD, MX and LX.
These data backs are quite different to the dial backs and digital backs. The data back features interchangeable inserts: a clock insert, and a memo insert. The clock insert can print an image of an analog-clock with hours, minutes, and seconds. You can also jot down a small text on the tiny circle in the middle of the clock face. Or write a small text on the memo insert.
The operations of the data back is simple. The only fiddly bit is that you must move a small blind down to cover a portion of the film in order for the clock image to be super imposed from the back in the proper manner. To correctly expose the clock or memos image on the film you must set the correct film speed using the dial on top of the housing. White numbers for B/W and red numbers for coloured film. Connect the cable to the flash terminal. A battery test button can be pressed to test the battery status and a red led flashes during exposure and of course if the battery is tested. There is even a terminal to connect it to an external battery source.
The data back takes a 6V battery,
There was also a ready-case made for the SPII Data II.
From a Norwegian price list from 1974, the SP II data with S-M-C Takumar 50mm F1.4 listed at 3 667kr, which would be 23 920 Kr in 2020-value, or about the same as a new Pentax K-3 III, about 2 900 USD.
This particular camera was one I came across on a British camera store. It has undergone a CLA and looks and works smooth. Just need to stock it up with film. It didn’t have the actual clock insert, but I have one with a data back that was made for the LX. The inserts are interchangeable.
If you have another of these Pentax Data backs in your collection, why don’t you share a photo of it in the comments?
---------- Post added 05-07-2021 at 10:31 PM ----------
One more detail, from what I know, the K2 DMD and LX are the only two cameras designed in a manner that allows for an interchangable back cover, i.e. you can order this particular type of data back without having to make adjustments to the camera body: The blind shown in the last picture above was put there in the factory. The K2 DMD was also the first Pentax where the motor drive could be bought as an option and used without modifying the camera body.
