Originally posted by nickthetasmaniac Why do you need the fast shutter speed? Have you considered alternatives such as ND filters?
If you can live with 1/1000 your options for M42 are practically endless...
Yes, I thought about Nd filter... The problem is that aside from the hassle, I am worried about stripping the thread. I feel like I have damaged the thread on my Fuji 16mm F1.4 lens, but at least that lens is replaceable, even though it's not cheap. Some of the lenses I'd like to shoot are hard to replace, like Meyer Optik Gorlitz 75mm primoplan, and some others have bent filter ring... Plus unfortunately I am not the kind of person to use only one lens, I keep changing them even during a day..
---------- Post added 07-29-21 at 06:11 AM ----------
Originally posted by Jonathan Mac The vast majority of cameras with an M42 mount only go to 1/1000s maximum and I don't think any of the ones from Pentax go above that.
I have a Chinon CE II Memotron re-branded as the RevueFlex 5005 which has an M42 mount and goes to 1/2000s. It's a nice camera, quite big and very solid, which stops down the lens and takes a meter reading just prior to the exposure, a feature not many M42 cameras have. So far I've only run one roll of film through it but it's a camera I enjoy shooting and I'd recommend it. They're not particularly well known and from what I've seen many come with the 55mm f/1.4 lens, which is a good performer.
Beyond that, you might have to go for a K-mount camera with an adapter. Apart from the LX I think you'll only find greater than 1/1000s on AF cameras: the SFXn goes to 1/4000s and the Z-1 and Z-1p go to 1/8000s, though AF cameras are worse than most MF cameras to focus manually.
Thank you! I don't know this particular model, but I'll look into it. Do you know if it's one of the cameras made by Cosina?
---------- Post added 07-29-21 at 06:14 AM ----------
Originally posted by othar It depends what you consider a fast shutter speed.
My Zenit E tops out at 1/500 sec, I guess this can be considered slow.
My newly acquired Pentax Spotmatic and my Praktica MTL 5 B reach a shutter speed of 1/1000 sec. Both cameras have a mechanical shutter and will need a batterie only for metering
Yes, all my soviet cameras top out at 1/500. I did have a Zorky that had a 1/1000 and was much older than the Zenits...
It's a perfectly useable speed if you don't mind stopping down, but some of the lenses I'd like to shoot lose their charm when stopped down...
