Originally posted by Daveee Is it just me that the Pentax MX's advance lever was kinda rough? Some lubrication on the gears helped a lot; but it's still not as smooth as the other cameras.
I currently have two MX’s, and have owned another three bodies at various points. I’ve also owned/used a lot of 35mm bodies from the same era.
I’d rate the MX advance as middle of the pack. Not as good as an M2, SV, or F2, similar to a SRT101, and much better than an OM1.
The biggest ‘downside’ of the MX advance is the long throw, but it should definitely be smooth. If yours is noticeably rough I’d suggest it isn’t working as it should. Keep in mind that there’s often a lot of sample variation on gear this old.
Which ‘other cameras’ are you talking about?
