Hi, i´m new to the site and to the film world. I wanted to try it and bought a Pentax ESII for cheap with a broken lens, stuck mirror and light meter not working properly. I replaced the lense for an EBC Fujinon 55mm 1.8 that i had until i can find a SMC Takumar (pretty rare where i live it seems). The stuck mirror was easy to solve thanks to the info in this site and some videos on Youtube, but the light meter still has problems.
The batteries that i could find are some new LR44W, I could not find the SR44 ones and for sale online are SR44W. Dont know the difference between the last two.
First: When testing the batteries in the camera (AUTO shutter and battery check button) the needle dorps down to 1/1000 and not to the middle (between 1/15 and 1/8) as the user manual says. I don't know if this is because of the slight difference of the batteries or the cameras light meter. If it´s the batteries then the second issue might be solved by installing the right ones.
Second: When using the auto mode with the stop-down switch engaged the meter shows 1/30s with a bright source and 1/4s or 1/8s with a dark one. Shutter speed doesn't seem to change.
Manual shuter seems to work fine so a can still use it but it would be better if the light meter could work too for auto.
I couldn't find anyone that had the same problem, that's why i'm writing this. Any help would be really appreciated.
The camera with lens:
Viewfinder at battery check:
Viewfinder at bright source (auto):
Viewfinder at dark source (auto):
