Originally posted by SelrahCharleS Do you develop the half-shot roll then? Or take note of where you were and advance to that point with the lens cap on to finish up the roll at a later time?
You can do it either way...
In the film era, if it was a roll for work, I would develop it and waste the rest of the roll. There was typically a hurry involved...
Nowadays, I'll rewind it, write the frame number on the leader with a sharpie marker, and then load one frame past that when I want to shoot the rest.
That works pretty reliably. And that's a great way to film-test a couple of cameras at once...
For the issue the OP is having, I'll join the "intermittent shutter issue" chorus. It may be the mirror, too, but it sounds to me like the shutter isn't happy for whatever reason.
It may need more than a CLA (Clean, Lube, Adjust), which will likely be more expensive.
And I'm afraid I don't know a Canon expert... does the Ftb have the AE1 mirror bearing squeaking issue? Is every frame shot accompanied by a sound like a tortured rodent?
-Eric
