I posted a photo and description of the rig I’m using on flickr:
This is the description from the flickr page, with some edits.
I developed the setup for an academic archival project at the University of Vienna and the aim was to get the best possible quality with minimal compromises, but also to keep expenses low where it did not matter.
Parts involved:
1. A massive old Polaroid copy stand that had been there for decades.
2. Manfrotto 338 leveling base (to ensure that the optical axis is perfectly perpendicular to the film). A mirror helps with the adjustment.
3. No name Arca Swiss standard clamp.
4. Novoflex Castel Q Focusing Rack (not needed with part Nr. 8 but useful with 120 film and for normal copywork).
5. Pentax K-1 body. The 36 MP of the K-1 combined with its Pixelshift technology are sufficient for most negatives and slides. Given that what we see as grain in DSLR scans is a combination of film grain and aliasing artifacts, the extra resolution offered by Pixelshift makes a real difference. The effective resolution with the K-1 is about 5000 dpi.
6. Schneider-Kreuznach Xenon-Zirconia 2.8/89-0001 lens (89mm f/2.8) with Schneider focusing unit and extension tubes. This is an industrial line scan lens optimised for 1:1 that for all intents and purposes is free of distortion, mechanical vignetting, chromatic aberration and has and extremely high resolution across the frame (but only at or very close to 1:1). This is what we use for 35mm film; for 120 film we have a less expensive but also very fine 1:2 line scan lens from VS Technology, the VST VS-L12056-05/V (120mm f/5.6).
7. Durst Sirioneg film holder (from a 6x7 enlarger) with AN glass below and various format masks above the film (which is always copied looking at the emulsion side). The film holder sits on aluminium rails glued to part No. 8 and its position can be adjusted by sliding it back and forth.
8. The basis of an old microscope that offers two extremely helpful improvements: focus micro-adjustments, and a sliding table for precise film positioning (left to right and rotation). The rotation thing is important because rotating digital images in software causes artifacts that can be clearly seen for instance in the grain structure. This part is only used with 35mm film because the opening of the sliding table is too small for medium format. For MF it is replaced with an opal glass plate with a cardboard mask.
9. Kaiser Slimlite Plano LED lightbox (produces better colours than the older tube lightboxes). For copying colour negatives it can be helpful to use a CC 30C filter to counteract the orange mask and better use the dynamic range of the sensor. This also improves colours with many negative films but not all.
10. The camera is connected to a MacBook Pro and operated via Pentax’s Image Transmitter software. Images go into a dedicated folder and can immediately be checked in full resolution via Adobe Bridge and Photoshop.
Since the lightbox illumination is not totally even and some optical vignetting is unavoidable, we take a flat frame of the illumination at each session and use it to automatically correct the images via a Photoshop action (I am indebted to DrTebi for helping me to understand how to best do that). The raw images are processed using a linear camera profile, something which helps especially with slides that are often copied with much too high contrast.
The best focus setting can only be found with bracketing focus and checking the results. With a decent holder, the focus setting can remain unchanged for the whole session. Copying is done in near darkness. I also tested the available Pentax macro lenses and found that the D FA 50mm does a better job at 1:1 than the D FA 100mm. The latter has a certain amount of lateral CA, which does not do a lot of harm with B&W film because in any case it is advisable to use the green channel only as it is the sharpest with most lenses. But the D FA 100mm is not the best choice for colour film.
