Originally posted by ProfessorBuzz What specific models of flash are you using? eg AF280T ?
What mode is the flash in vs the camera mode? e.g. Manual or TTL on the flash; X or ???? on the camera.
How is the flash connected to the camera? Side terminal or hot shoe?
The first film that showed the problem was shot with a minolta flash in auto mode (= read the fixed aperture from the table on the flash for your ISO) --- I bought this particular flash because it allowed for higher aperture than Pentax's flash units, and I like the mix of available light with flash light). Camera was set to 1/30 for this film.
I tested a similar setup (see below) with a Pentax AF280T in auto mode (red setting) and 'X' shutter speed, because even with the flash in AUTO mode, I get a mirror lock-up when the LX is on anything other than 'X' shutter speed.
I checked the manuals of the AF280T and the LX and although there's strong suggestion to use the AUTO shutter speed setting also for a non-TTL AUTO flash unit, there's also a table that says you can use all manual speeds from X down to 4s for AUTO flash.
Actually, thinking about this, what difference would it make for the camera if you use a flash in AUTO mode (either Pentax's or generic) or in manual mode? Either way the camera must be set with the aperture that you read from the flash's back panel and some shutter speed slow enough for the shutter to be completely open.
And on my LX, the flash sync signal seems to be triggered before the first curtain opens, while in fact it should be triggered when the first curtain is fully opened.
Quote: It's hard to see this visually, and with the back open, the OTF meter doesn't work, so not sure this is a good test.
Am I not right that in manual shutter speed the OTF isn't doing anything? When looking through the shutter while triggering the exposure button, I could clearly see the difference between using my LX and my MX (same lens, same aperture setting, same flash settings). On the MX I saw the flash light, on the LX I saw just the available light, as with no flash. The flash fired in both occasions.
When I set the LX to some very slow speed, I can see that the flash fires before the shutter is opened.
Quote:
Could easily be an electronics problem or an electrical contact problem.
Or (forgive me) operator error.
Or camera and flash are just too old and worn out.
How old is the camera? 1980 vintage (42 years old) or 2001 vinage (21 years old). After 10 years, a lot of electronics especially capacitors fail... so everything is suspect. Metering can be checked against a reference grey card. Use 2 cameras with same lens under same light to compare, if you don't have a better way to check.
Can't be done economically, no market, components from 40 years ago aren't avaialble, and higher margins making other products.
Yep, it would be nice, we all have frustrations when things come to their end of life.
Let us know what your exact setup is per your earlier questions, and maybe we will have some ideas.
The metering without flash on itself looks OK, comparing to other camera's, I mean: what the meter in the viewfinder tells the exposure should be. But for testing if the actual shutter speed is OK, especially in AUTO mode, I'll only be able to test this with actual film, I'm afraid?
I was also testing the shutter speed in AUTO mode without film, just on an auditive basis, and it was much longer than what the meter told it should be, but I read that's because there's no film inside, and the meter in AUTO mode relies on light reflected from the film, which is not the same as light reflected from the bare pressure plate, so that is definitely not a good test.
My only way will be, I believe, to abandon flash on my LX and to run a test roll and note down when I'm using AUTO and manual modes and check the results and continue from that...
Best regards,
Vic
