01-30-2022, 09:11 AM   #1
Shutter cocked or not when stored
It’s the usual question, but I recently bought a new old stock Ricoh XR Solar (in kit with its mint new old stock Rikenon 55 1.2, see my post in an Italian forum: Scimmia 55 1.2 Cosina, Ricoh, Revue o Porst? - Pagina 2 - Analogica.it) and in the box I found this warning that means: “please store this camera always with shutter cocked”.
This Ricoh XR Solar is based on the old Cosina CT1 and has a Copal shutter and I recall that the suggestion for Nikons FE/FM was to leave the shutter released. Now I am confused.
What about our Seiko shutters in Pentax M, A, P bodies ?
Ben
IPad Air (4th generation)  Photo
01-30-2022, 10:40 AM   #2
Otis Memorial Pentaxian
Follow the instructions in the box for your XR Solar. They likely have to do with the solar feature. As for other cameras, whether to store cocked has been a matter of ongoing discussion. I tend to leave my cameras stored uncocked, particularly those with leaf shutters, but I am sure there are arguments both was for various models.
01-30-2022, 10:52 AM   #3
The camera is 100% mechanic, the solar panel are there just to feed a capacitor for the light meter, so I believe that the shutter cocked suggestion has (had) to do with the tendency of the mechanism to slip and not cocking the shutter, which is typical for aged Pentax M series bodies.
01-30-2022, 11:15 AM - 1 Like   #4
Not a Number's Avatar
A cloth shutter should be left uncocked as much as possible. Keeping it cocked puts tension on the shutter tapes/ribbons causing them to stretch. This will affect the timing if there is slack in the tapes.
01-31-2022, 10:33 PM   #5
Leaving a shutter cocked leaves tension on all the springs in the shutter. That generally is not good. That is why Pentax designed the 67 to leave the shutter uncocked at the end of a roll.
02-14-2022, 10:24 PM   #6
disconnekt's Avatar
If for a couple days it'll be fine (like if you have a roll of film still in the camera & you know you'll be finishing in a short time), but for anything mid- to long term, like Pentaxus & Not a Number said, its best to leave it uncocked.
cocked, cosina, ricoh, shutter, stock, xr, xr solar
Pentax LX shutter stuck in the cocked position Robert_1 Troubleshooting and Beginner Help 13 05-14-2019 02:57 PM
Pentax LX Cocked Jammed Wompa Troubleshooting and Beginner Help 2 03-10-2019 08:42 AM
Is Image Finishing setting stored in metadata? bobdobbs Pentax DSLR Discussion 3 01-16-2017 02:26 AM
Iso setting not stored when changing program in the dial: K7 phidias81 Pentax DSLR Discussion 5 04-06-2015 07:30 PM
Is healthy for shutter to stay cocked? fandart Film SLRs and Compact Film Cameras 11 10-19-2012 02:55 PM
All times are GMT -7. The time now is 01:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
